ข่าว vBulletin 5.5.X (5.5.2, 5.5.3, and 5.5.4) Security Patch Level 2
A security update with respect to custom avatars has been made by vBulletin in the following security patch.
You can download the patch for your version in the Member's Area
We have made patches available for the following versions of vBulletin Connect:
  • 5.5.4 Patch Level 2
  • 5.5.3 Patch Level 2
  • 5.5.2 Patch Level 2
Installing the Patch
  1. Download the appropriate files for your version of vBulletin 5.5.X
  2. Upload all files found within the zip file. Make sure to overwrite the existing files on your server.
Older Versions
If you are using a version of vBulletin 5 Connect prior to 5.5.2, it is imperative that you upgrade as soon as possible. For more information on upgrading please see Quick Overview: Upgrading vBulletin Connect in the support forums.
vBulletin Cloud
This security patch has already been applied to all vBulletin Cloud sites.
202
325
470
  • บทความ บทความ
528
